What is this called?
I was looking at my bearings because i was going to get new ones soon. i have a traxxas xl-5 with a vxl motor and the same bearings it came with stock. so i was wondering what this was. i looked in the exploaded views and i found out it's just a washer thing. do i need to replace this? or just bearings? thanks. here are the pics.
always dreamin[8D]
always dreamin[8D]
My Feedback: (23)
WI
RE: What is this called?
Its a traxxas fiber washer- http://www3.towerhobbies.com/cgi-bin...?&I=LXJJ88&P=7
Its to keep the stub axles from having to much slack and reaking havoc on your bushings/bearings.
ORIGINAL: Takedown
thanks
My Feedback: (23)
WI
ORIGINAL: Always Dreamin
so if i just bought that and some new bearing carriers/bearings thats all i would need? do i need to replace those washers frequently?
thanks
ORIGINAL: Takedown
thanks
i did a search on tower for the part number. i found it in the exploaded views... it was a plastic washer. just thought i would ask before i ordered.
ORIGINAL: brushlessboy16
xl-5's come with bushings, get rpm carriers with 5x11mm bearings
My Feedback: (23)
WI
so i will not need the washer when i get bearings?
NJ
u might be able to make them out of something, i used small o-rings on my rustler so they squished when i tightened the wheel on and kept everything snug
ORIGINAL: hockey911
i used to play paintball and i have those 0-rings, would those be good untill i get new 1s?
