rustler vs bantit o.O
Alrighty then, I was planning on getting either a regular rustler or bandit (both electric) What's better? I heard they're the same but just different chasis? Help! Thanks!
p.s. can someone explain the differences and advantages of a 6 cell or 7 cell battery for one of the above cars? Thanks again!!!
RE: rustler vs bantit o.O
ORIGINAL: whothefashizle
the advantages, you will have faster speeds. plain and simple. as pede kid said.
the disadvantages, your driveline will wear faster, more likley to break parts, your motor will not last as long. please let us know what one your getting (vxl, or xl-5). that will help make the desision of 6 vs 7 cell much easier.
TX
The Bandit's chassis is exactly the same as the Rustler's. The difference is in the longer suspension arms of the Rustler front and rear, and of course wheels, longer front and rear shocks and the front body post that screws into the shock tower. The shock towers are the same in both front and rear.
The Bandit will go faster due to it's smaller wheels (and hence it weighs less to) and more streamlined body design, and it uses a larger pinion stock to compensate for its smaller tires. I have both and don't prefer one over the other. The Rustler will go over a little more rough stuff, while the Bandit can still hop over smaller jumps with ease, though it might bottom out a little more often.
The Bandit will handle better in general while cornering and such over less bumpy surface (on-road etc.), but tends to flip at high speeds (30+ mph due to it's narrower design (though the Rustler can do that too turning sharp at 35+ mph....).
In case you're wondering about the 40+ mph, all of my cars are brushless ...
It won't cost much to convert one to the other, as listed above the arms, shocks (if that really matters to you) and front body posts, wheels, and the pinion gear are really what make it different.
oh, cmon slo-v, who wouldn't want a rustler with that picture i'm assuming thats a xl-1 or atleast was. that looks very clean if it is.
xl-5 is the one i'm getting, and what?...burns up the motor? o.O best be carefuls
TX
Both of mine are XL-1 models and upgraded from there. Here are a couple of pics of my Bandit from last year when I installed the Novak GTB brushless in it. It looks more beat up now though, need a new body....
