Does gear pitch matter when selecting pinions??
TX
I got a stock XL-5 rustler and would like to lower the pinion to run short distances and do wheelies. Do I have to buy 48 Pitch pinion gears (which is what rustler have stock) or is it safe to get 32P pinions? I stopped the hobby for a while and now I have more time but forgot a little about it in 6 months. Thanks.
RE: Does gear pitch matter when selecting pinions??
ORIGINAL: RCJesse
TX
I tried to find 32-pitch spur gears that would be small enough to fit the Rusty, but have not been able to so far. The smallest one I've seen is 64 teeth, and I use that in my E-Maxx. It is still too large to fit in the Rustler because it hits the bottom drive shaft output. Even then, I would need a very small 32-p pinion, and 10-12 teeth is the smallest I've seen which are still kinda big. Still, a 54-58t spur is what I want but can't find one yet.
Just know if you do use 32 p gears, it will be more noisy.
You cannot mix and match different pitches for the pinion and spur gear. For 1/10th scale stick with 48p. 32p is for monster trucks like the E-maxx and 64p is for 1/18th scale. If you use a pinion that doesn't match the spur in terms of pitch, you will damage the spur gear very quickly.
TX
Yeah I forgot to mention that you can't mix different pitch gears with each other, i.e. you will need the same pitch pinion/spur gear. So when I said I wanted to try a 32p spur gear in my Rustler, that went without saying that I was going to use a 32p pinion gear as well. Hope that clears it up.
