Need help finding the right tire and rims for under 50$
RI
im going to use my tallons for on the road and im thinking of getting a new set of tires
what is a good pair with a lot of good grip, and a matching rims, something that looks nice, im looking to spend about 50$, tyvm all im also trying to find a pair and it must be at tower hobbies
RI
RE: need help finding the right tire...
how about this set up?
rims http://www3.towerhobbies.com/cgi-bin...?&I=LXLCB8&P=7
tires http://www3.towerhobbies.com/cgi-bin...?&I=LXDU11&P=7
RE: Need help finding the right tire and rims for under 50$
I don't think those agitator rims have the correct offset to be used on the stampede. RPM makes a few different styles of rims just for the rustler and stampede, if you look around the 1/10 scale wheel section on tower. Here's one example: [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMTA1&P=]RPM Bully[/link]
ON, CANADA
Does anyone know of any black rims that will fit a stampede? Possibly ones that come with tired prefitted?
RI
how about these for rims?
1. http://www3.towerhobbies.com/cgi-bin...?&I=LXMSY3&P=7
2. http://www3.towerhobbies.com/cgi-bin...?&I=LXMSY5&P=7
NC
here is what you need:
Dish:
http://www3.towerhobbies.com/cgi-bin...?&I=LXRSK3&P=7
Spoke:
http://www3.towerhobbies.com/cgi-bin...?&I=LXPZC9&P=7
Tire:
(these are great on grass, because you need spikey pins, but there are enough of them to work great on loose soft-packed dirt.)
http://www3.towerhobbies.com/cgi-bin...?&I=LXDT95&P=7
If you want true, made for grass only (do NOT run on road at ALL!)...
http://www3.towerhobbies.com/cgi-bin...?&I=LXDT93&P=7
Dish:
Spoke:
Tire:
MO
the tractor gators are great for grass and muddy or loose dirt. if you want more ground clearence check out the masher 2000's
RI
would these http://www3.towerhobbies.com/cgi-bin...&I=LXSTA4&P=ML fit with these http://www3.towerhobbies.com/cgi-bin...?&I=LXLCB8&P=7 ?
IL
Those are both 2.2'' so yes they will but make sure to get a pair of front and a pair of back wheels not just fronts like you posted, just a heads up.
Pontiac K
Pontiac K
RI
why do you need 2 different kinds of rims? lol i put my rims with my pede on back or front idc lol
WI
You will need two diffrent pairs of rims for the front and back. Due to the offset.
http://www3.towerhobbies.com/cgi-bin...?&I=LXMSZ9&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXMTA1&P=7
IL
The fronts don't have the stuff to get power, they are just there for the ride and the rears have the stuff to put the power to the ground.
Pontiac K
Pontiac K
