Official E-FIRESTORM thread
#7451
RE: Official E-FIRESTORM thread
ORIGINAL: Krazy Chicken
probably going to get lipo so i can run it full power lol
ORIGINAL: redfisher1974
Try lowering the timing....Or get a lipo.
had it off before i ran it lol
It's a complete different driving experience.
Be ready for mind blowing fun when you buy it!
After the Lipo experience my Piranha went to the trash...
#7452
AB, CANADA
Thanks to you firestorm users, and your awesome advice...
PROJECT:'RALLY-STORM GTR' is complete!
The car is composed of:
>stock e-firestorm chassis
>duratrax 4600mah 7-cell NIMH battery
>2'2 Proline 'Dirt-Works' tyres
> Axail 12mm hex 'Rockster' flat black rims
>Tamiya 190mm touring car 'Xanavi Nismo Nissan GTR (R35)' body
>Castle Creations 'Mamba Max Pro' 5700kv ESC+Motor
Optional Parts I might want to add:
Aluminum shocks
3s lipo
DX3S or DX2S radio+servo & reciver
Aluminum shocks
3s lipo
#7457
It's going to hit 50 degrees today and tomorrow. Hopefully it's not too wet so we can run our today too. The rain coming on Sunday should get rid of the rest of the snow.
Heading out to HobbyTown today. Let's see what I come home with.
#7459
A 2.4ghz radio,Brushless setup, 3s lipo and charger....ESE motor plate with heat sink.
#7461
AB, CANADA
ORIGINAL nitro newby
that looks awesome, oh and, here are the pic's i said i would post.... internal server error... will try again later.
#7462
AB, CANADA
ORGINAL redfisher1974
Hey that looks great, How did the body fit?
Just small adjustments like body post hole placement and cuting off sharp edges.
#7466
Still waiting for my discharger and anderson power poles....
Thanks for the reminder.
#7467
TN
It's warmed up some here the roads have been dry for days and yesterday our yard dried out and
hpi my pics are only 2 of a broken piece Wil take more later
#7468
ON, CANADA
I picked up a camber gauge the other day and think I will pick up a toe gauge too. My storm is set up with two degrees of negative camber front and rear as a starting point. I will measure the ride height and fill out a setup sheet and start following this a bit more.
#7469
1 Post
ORIGINAL: Stryker USMC
THAT is what they are called. I'm going to look for those power poles when I go to HobbyTown.
#7472
TN
Just got back from my grandads got to run my efs out in the open in gravel roads and a field it was awesome didnt got hot either although it's only like 50 degrees outside
#7473
They also are called Sermo's connectors and duratrax makes a clone of them too.
I use those on everything, have for many years. They are Anderson Powerpoles, look on the end of the plastic plug. In very small letters is Anderson Power. I always solder the ends and they do make different sizes for larger wires. Great product....
#7475
Do you have the anderson crimper?
I don't have the crimper but my neighbor does, his wheel chair uses those connectors and he had to replace some of them so he bought the pliers and a bunch of connectors. He crimps his but I've always soldered mine, they work great either way...
