Official E-FIRESTORM thread
#1652
1 Post
RE: Official E-FIRESTORM thread
ORIGINAL: robertbell6
do you have the pro or sport? how is the tq from a dead stop?
#1656
so i ordered the novak havoc 8.5, hopefully (fingers crossed) i can keep this one for awhile, thank god the guys at my lhs are bomb and will take this 7500 back
#1657
Hi guys!! Nice to find a thread delicated for E-firestorm here! I will be getting the E-firestorm 10T (Non-flux version)... Remove all the electronics. [:-] And load my Tekin R1Pro with 4800kv motor into the storm...[:-] I'll be getting the HPI option as well like Uni-drive shaft, Alu suspension mounts/braces and Alu shocks for it.
Anyone here ever kill the stock turnbuckle? I'm wondering if the stock turnbuckle are durable enough... Those HPI titanium turnbuckle is not cheap, does it justifly the cost? Please advise here...
Thanks in advance guys!!
#1660
the losi esc has a fan that comes with it, any decent jump or roll over and the fan shuts off, i have to push the fan down to get it to turn back on
#1661
1 Post
Runs cool to....I might try to go up to a 21t pinion and see if i can touch 40mph if the temps stay low..You might have to play around with the settings untill you get it where you like it...
#1662
1 Post
#1664
ORIGINAL: evo165
#1665
stock turnbuckles are just steel turnbuckles.i replaced as soon as i got my Flux just because i wanted some color contrast.they will break with a hard enough impact.i have snapped titanium ones as well on my Savage.the choice is yours.i dont think the HPI's are that expensive compared to the Lunsfords.
#1666
1 Post
any rolling wheelies? or only from a dead stop?
#1667
AZ
I went with Lunsford GT2/T4 turnbuckles....Amazing
Well last night I began to build my shocks(HPI Options) and the aluminum collars are wayyyyy to loose. Yes the O-ring was installed. I purchased some new ones and will be contacting HPI regarding the issue. Also I have all four of the conposite arms on and shimmed everything with a Losi shim kit. NOW SLOP IN THIS TRUCK AT ALL NOW.
#1668
ORIGINAL: bigmd74
Can anyone tell me the reason why of most 2wd truck racers like to used ribbed tire on the front instead of all round SAME as the rear. Please enlighten me as i'm still newbie on stadium truck.
#1669
ORIGINAL: Spoold95
#1670
I built mine a couple of weeks back, and the opposite is true of mine, they are almost too tight to adjust, which doesn't matter too much really, but compared to the TRF dampers on my durga they are very tight.
Cheers!
Cheers!
#1671
Ive orderd a set of Proline Masher tyres for the rear of my flux,...and was wondering what i have to modify to run these...(pinion, spur etc..)? The overall diameter of these masher tyres are about 1 inch more than the originals.
I was thinking maybe a 17 tooth pinion or would i need to go lower?
#1672
1 Post
ORIGINAL: drjunk
#1673
ON, CANADA
Here's my e-firestorm with the latest addition: Yeah Racing Threaded Aluminum Shocks, 90mm front, 100mm rear. Haven't tested them yet but they do look purdy!
#1674
ORIGINAL: Willystylz
