Going Slow is The Way To Go - Tamiya CR-01 Resource Thread!
#501
TX
RE: Going Slow is The Way To Go - Tamiya CR-01 Resource Thread!
I went for a drive today and took my camera. [sm=49_49.gif] I really need to get the Novak Crawler System for this thing...or at least a better ESC.
http://www.youtube.com/watch?v=IOWKj11m8bw
Tomorrow I may have to take the Slash out to the same spot and make another one.
#502
What ESC do you have right now?!
I just did my paint job tonight... my worst paint job ever...
Should have just gone w/ a single color paint job.. oh well.. I guess I got my bash shell now....
#504
TX
#506
I sprayed the gun metal first, and some got on the shell (where I was planning on putting yellow later).. so it looks pretty lousy if you look closely.. I should have just done the whole thing in gun metal..
The yellow / white is not bad..
Anyway, like I said, bash shell.. ha! Can always take the light unit off and mount to other shell later, so it is no big deal!
ORIGINAL: rustleracer23
lets see it it cant be that bad
#507
Alpha, I love the video! That's just about how I would use the CR-01 if I get one. I think I'd get bored with pure rock crawling, but the trail type driving you did in the video really makes me want to buy one......now I'm torn between this or a Slash(I know they are completely different, but I want both and my budget is limited).
#512
TX
Nice rack, LB, but you might want to reconsider. I kind of wish I had not added the roof rack to my Landy body because it makes it a little bit top-heavy and wobbley. [] Now there are holes where I mounted it, so it must stay.
#514
Alpha, that was an awesome vid, nice camera angles, the whole thing looked very scale. Sure the rack might have made the truck top heavy, looks cool though...
#516
PA
ORIGINAL: Lunchboxer
Be sure to post the article link here too so we can check it out!!
You can see tons of pictures of the build here: To see more just follow the links at the bottom of each page. There is a video up there too.
http://clodzone.com/?p=1025
#518
PA
I think I already mentioned that I gave my brother the wheels/tires off my Axial to use on his CR01. Well here are a few pictures of it with them on. I stripped the green anodizing off the beadlock rings with oven cleaner, and then painted them mat black. I also swapped the beadlock rings around so the insides ones are now outside to give it a cleaner look.
Look at that flex!
Look at that flex!
#519
Yeah i twisted up my shafts aswell, thinking about up grade. will keep you posted. I wish Tamiya would revisit the areas that need fixing on the CR01, i know it's not going to happen but it would be nice, maybe ill sent them an e-mail....
#520
I wonder if there's any cheap alternatives.. or you'd have to go w/ some full metal unit ($$$) [:@]
#521
PA
Well if MIP comes out with a set like they did for the AX10 then it would be about $50, not too terrible. I think RC4wd is making a set but they'll probably be twice as much.
The other alternative is going with one of the Traxxas shafts. I've been running Stampede shafts in my Axial for a while without a problem, but if you're really wanting to go bulletproof I think you can modify Jato shafts to fit.
#522
Those Jato shaft -> I wonder why they are better.. I have a couple of them lying around (when I was working on my TLT, which, reminds me, that I should get back on some of my projects, ha ha!) and I am curious as why they are better...
I mean, it looks like the shaft is twisted at the shaft's body.. not breaking the universals.. Jato shafts use better plastic?! Hmm...
#523
Oh yeah, Dr. Evil, thanks for posting those pics and the link! I like those pics.. you must use some sort of light booth, eh?! Looks good! The video is cool too! Nice! [sm=thumbs_up.gif]
#524
PA
I haven't seen Jato shafts in person but I've heard they're much stronger than the Stampede shafts. I just always assumed they're larger in some way.
As for the pics, Thanks for the good words. I don't use any type of light booth or anything like that. I'm just using white paper as a background and a good bounce flash.
#525
I use the Jato shaft in the TLT and REVO shaft in the TXT.. I still got one left (Jato shaft) so I will try that out if (when? ha!) the Tamiya shaft fails..
