Tamiya Pajero-Collective Build
#727
NJ
RE: Tamiya Pajero-Collective Build
ORIGINAL: eichkay
On my setup ive put F350 shocks on the rear which measure 95mm but they are soft and compress a bit once installed but allow for allot of droop in the rear.. Ive kept the stock shocks on the front but i put a spacer of about 3mm at the top mount on the chassis to drop the shock down after notching the front A arm to allow the C hub to not bottom out and restricting the travel, i have a nice soft front end which gets full up travel with the stock springs.
http://www.rcmart.com/catalog/rc-dam...?cPath=389_390
or should i go with this
but that would be for the rear cause the front proly wont accept those or should i use these
http://www.rccarparts.biz/product_in...c4437127e99d22
whaqt would give me the best lift as in highest?
#728
Yeah I'd be interested in knowing what an ideal "lift" setup would be for both the front and rear. I have a Pajero coming in the mail!
#729
Finally got a bit of snow in the UK, sadly on my first day back at work after the holidays. Took the Pajero out though and had some fun, although it was too dark to take pictures.
Did take a few when I got in...
#730
Does the Pajero need a decent sized Servo for the steering or will any basic Futaba S3003/4 work? Would you want to get something beefier if you wanted to do rock climbing with it??
#731
NJ
ORIGINAL: Zerrminator
#735
If I'm planning on going with the basic two tone paint job for the Pajero (say Blue with Silver Trim) should I paint everything Blue first and then mask off the trim later to be sprayed Silver?
Does anyone know the recommended colors that Tamiya lists for this re-release kit? I want to make sure I have the paint since my kit is in transit.
thanks
thanks
#742
OH
ORIGINAL: lee172
i dont know quite how else to put it! it has no rear lights! or no front indicators..
#744
ORIGINAL: BigTb17
It doesn't come with any. You have to paint them on if you want them.
ORIGINAL: lee172
#745
ORIGINAL: TamiyaKrawler
here i lifted it the rear is lifted more still working out the kinks
