The Official Traxxas Slash short-course race truck
#2876
ON, CANADA
RE: The Official Traxxas Slash short-course race truck
awesome thanks,
it sucks that i have to wait till next week to test my truck gotta wait for my mamba monster
#2878
I am new here and new to RC in general so I apologize in advance for my lack of knowledge. I recently purchase a Traxxas Slash 2wd and took it to my local dirt track to have a little fun on some jumps. I noticed after i ran it a couple times that it now pulls to the left pretty quickly. I am able to overcome most of that by adjusting the steering trim, but I 'm not aure thats the proper way to correct it. What should I look for that could be causing this issue? Any help is greatly appriciated!
#2879
ON, CANADA
ORIGINAL: offthestreet
#2881
#2882
#2883
ORIGINAL: DriftingDragon
first thing i would say is unscrew the servo horn turn on your truck so that it resets and then reattach it, if that doesnt work make sure none of the parts are broken
I have absolutely no idea how to do this. Again, I am a COMPLETE novice. I did my best to look over all the moving parts and I noticed and noticed that the rear A-arm, or at least thats what it looks like to me, has a main connecting screw that is very loose and has almost fallen out. I also noticed that the car turns very sharp right, but does not turn as sharp to the left. Does it sound like this might be something related to the servo?
#2884
Have you taken off your tires to check out the bearings? you could have something stuck in one wheel that is binding
#2885
ORIGINAL: Andyjk
Check that the steering posts haven't slightly popped out on the underside of the car. If so, just slip them back in and it should be good to go
#2886
ORIGINAL: brianjskora
I haven't done anything yet, but thats seems easy enough to look at, even for me. Thanks
#2888
Traxxas has full diagram on website. Find the slash and its images or downloads
Awesome...Thanks!
#2889
Hey thats cool, dont stress... here this link should help... any questions PM me...
[link=http://traxxas.com/forums/showthread.php?464055-Slash-Steering-setup-bellcranks-toe-link-pictorial]Click here for a Slash Steering setup / bellcranks / toe link pictorial[/link]
#2890
ORIGINAL: phmaximus
#2892
I get my tools off ebay, dynamite brand hexs. The most common size on the truck is 2mm, but you will also need a 2.5, and a 1.5. I would pick up two 2mms because I use it so much I wear them out ( I rebuild weekly ) http://www.ebay.com/itm/Dynamite-Hex...item2a18ccdd9b
If anyone is looking for a new castle 3800 sct system with MMP ESC and fan, let me know. $175
#2893
Double post
Wow! That's awesome! Thanks for the link. I have some work to do this week. One question...Where can I get the right tools to work on these trucks? Every tool I have will fit my actual car, but nothing this small.
ORIGINAL: phmaximus
#2894
#2895
ON, CANADA
ORIGINAL: phmaximus
Hey bud Ive got a tip for ya... replace all the hex bolts with phillips head bolts/screws.... then they will never strip.
also do you guys like my paint job on my remote
#2897
ON, CANADA
just installed my monster but i gotta wait for my batteries to charge[:@]
EDIT just finished running it and i need ideas to stop flipping it i have the suspension as low as it can go
im running 12v and 16/90 to me it seemed to run about 75kmh on half battery
#2898
For high speed runs i found a gyro helped...
but its just manufacturer's charistics for this model....
there are LCG kits but why bother... whats that a scale speed of 750km/h
#2899
MI
ORIGINAL: offthestreet One question...Where can I get the right tools to work on these trucks? Every tool I have will fit my actual car, but nothing this small.
1 | 5629A61 | 1 Each | Metric Cushion Grip Looped T-handle Hex Key, 2 Mm Hex, 6" Blade Length |
2 | 5629A62 | 1 Each | Metric Cushion Grip Looped T-handle Hex Key, 2.5 Mm Hex, 6" Blade Length |
3 | 57585A52 | 1 Each | Metric Hex Driver, 1.5 Mm Hex, 4" Blade Length, 6-5/8" O'all Length |
4 | 71285A149 | 1 Each | High-torque Hex L-key, 1/16" Hex, 3" Length |
5 | 71285A169 | 1 Each | High-torque Hex L-key, 1.5 Mm Hex, 3" Length |
6 | 71285A171 | 1 Each | High-torque Hex L-key, 2 Mm Hex, 3-3/16" Length |
7 | 71285A172 | 1 Each | High-torque Hex L-key, 2.5 Mm Hex, 3-1/2" Length |
I think Iwould like a set of screwdriver-handled drivers where the hex part is only at the end, but for the money these can't be beat.
#2900
MI
Very tired of my floppy, ugly, shot-up, unaerodynamic, stupid-looking SC body. Can I get some advice on something more along the lines of a Rustler body? Will a Revo body fit?
