THE Official Traxxas E-REVO Thread
#753
RE: THE Official Traxxas E-REVO Thread
ORIGINAL: Metallover
Take a picture of the servo. It worked before you cut the wire, right?
#755
ORIGINAL: Redvanmafia
that aluminum e-revo is $$$$$$$$$
#756
ORIGINAL: patrick12186
It was brand new (never used) before i cut it. It has the red, white and black cables going from the servo to the receiver and the black cable only has been cut completely through. Simple Example: _____ ______ (just like the line looks.sorry dont have my camera but figured that would be simple to understand)
#757
I want it.
Igot no problem sending it to you. im not gonna need it. shoot me a message with an address to mail it to. It may take a week or 2 to get there since Iam currently in Iraq but it will get there.
Does anybody on this forum have any good input for a great steering servo to convert my e-revo to single servo steering?
#759
I got no problem sending it to you. im not gonna need it. shoot me a message with an address to mail it to. It may take a week or 2 to get there since I am currently in Iraq but it will get there.
I want it.
#760
IL
I want it.
#761
ORIGINAL: KRO
The JR 9100Tis a great servo for the E REVO , mine has taken countless hits and still works like new , and I can hold the front end all the way down and it will still turn the wheels quickly .
Can i just plug and go?
#762
NY
ORIGINAL: traxxas4ever
Does anybody know if the brushless e revo comes with the castle link cables and software?
just got mine a month or2 ago......................nothing in there like that !!
(If you get the Momba setup seperately, it will come in that box !!)
#765
NY
I put a spool in the rear diff, and when I ran on 4s, everything was OK. Ran on 6s and my axles got tore up. Looks like the plastic housing (yoke) for the caps on the "U" joint by the diff ( not wheelside) melted and the universals ripped out on both rear axles. I just greased up Traxxas Metal axles. I am running the Traxxas extended rear arms in the 19mm position. Stock shafts from tranny to differentials, cant find any replacement shafts good enough to spend $$$ on. Anybody have any ideas where to get better driveshafts for front and rear transmission to differentials ????
Anybody have any problems with the Traxxas metal driveshafts ?????? (going from differentials to the wheels)
#766
ORIGINAL: moparmyway
... I am running the Traxxas extended rear arms in the 19mm position....
http://204.186.93.64/E-Revo-CenterDogBone.htm
#767
My Feedback: (27)
MD
I just fired up my new BL E-REVO and took it for a spin with 2 - 3S5000 Lipos. Lightening fast. I made a mistake of slowing it down by slowly reversing it and all the sudden it stopped responding to the throttle forward/reverse. I opened it up to check the tension on the motor pinion against the drive gear and tightened it up with little tension. Now it drives fine forward and reverse, but it seems to be very LOUD when it rolls. Did something get broken or is it just me now? It makes a loud sorta clicking noise, but other than that it runs just fine. Any help would be greatly appreciated!
#768
Hard to tell from a description, but your gears could have worn/broken a tooth or two off causing the noises. You'll have to make the call yourself and look closely at the gears and spin them around in different ways to see if something isn't right.
#769
RI
mine does the same thing and it is brand spankin new. i heard the noise the second i turned it on and i now have about 3 runs through it without any problems.
#770
My Feedback: (27)
MD
I was worried since it stopped working and I had to adjust the motor mount adjustment screw to bring it closer. Perhaps doing the reverse kicked it loose. Other than that it works, just noisy is all.
#771
CA
Anybody have thoughts on the new Maxamps lifepo4 batteries? I think they're overpriced ($270 +shipping for 6750mah and 9.9v), but might have some unseen benefits.
#772
No, anything maxamps is crap. The new packs aren't only overpriced, but they are using untested cells and their usual [not] matching technique. The constructions is probably horrid too. I'd stay away. The new LiPo packs are better. Check out hyperions G3 VX packs and Flightpower EONX packs.
Also, the thing about a123 or LiFe packs, is that they can't sustain a good voltage under load. They don't have much "punch" compared to Lipo packs. You need a new LiFe charger too.... Do yourself a favor and don't get those packs.
#774
All maxamps packs are like that. One guy got a pack with two 4200 cells and four 4000mah cells. They take random cells and throw them together into a pack without testing or matching the cells.
#775
CA
Is this from one guys singular experience, or your multiple experiences? I respect your advice, but I don't think one instance is enough to go off of.
