RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
e firestorm problems
Old 04-29-2008 | 04:43 AM
Default e firestorm problems
i am running an lrp a.i esc and a lrp fusion phase 4.1 10 turn i was runing for about 20 secs then the car goes as if the battery is extreemly flat like 2 km/h.?????? please help i need my rc for tomorrow!!!!!
Old 04-29-2008 | 04:51 AM
Default RE: e firestorm problems
sorry i plugged my blue wire into my yellow brushless motor wire what is that wire for anyway?? does a brushless motor require more current? for a 3rd wire?
Old 04-29-2008 | 08:37 AM
A brushless motor has 3 seperate coils, in the can, and the permanent magnets are in the rotor. Those 3 wires are used to send power to 3 seperate coils, typically in a wye (Y) or delta configuration... if your car seems to be going backwards when it should be going forwards, you can swap any two of those wires and the direction should change.
Oh and for sensored brushless like with LRP / novak systems, the color must (or should) be matched, otherwise it will get kinda confused like yours just did.
