PLEASE help me with soldiering
ok once i have a soldiering pencil do i need anything else to start soldiering cause i need to soldier some things on my evader. so can i get right to it once the pencil comes in?
some 60/40 rosin core solder. also depending on what you are soldering ive found it to be really helpfull having a hobby stand. basicly a block of wood with two aligator clips mounted on a strong wire or any bendable post. it s like having an extra set of hands to help ya!
NJ
and needle nose pliers untill you have held a hot wire waiting for the solder to solidify you dont know pain
here is a few items you should pick up..
http://www.radioshack.com/product.as...%5Fid=64%2D009
http://www.radioshack.com/product.as...5Fid=64%2D1866
there is also a stand like mentioned before. it has several aligator clips on it and a magnifying glass... helps hold stuff together so you dont burn your fingers. I cant find it on there site though...
How to solder
How to solder like a pro
How to solder PDF
VERY GOOD ONE!!! How to solder wires properly and more
Hope these shine some light on your soldering needs. It's not as simple as it looks but it isn't that hard to learn. Just takes time to PERFECT! a good variable temperature soldering iron is a blessing when it comes to soldering different sizes of items.
Good luck!
__________________
How to solder PDF
Good luck!
__________________
CO
How about going to the LHS and having them show you how to do it. This would be better than learning from the internet. Visual Stimulation is better than looking at a picture.
NJ
yeah... its better to have someone show you... I find it hard to explain the "touch" needed to get a good clean joint over a text medium even though I am (time to brag here) darn good with a soldering iron.
