motor heatsink/fan for rustler
so i got an integy heatsink/fan, i know shoot me now!
and the heatsink fits fine, its just the fans plug wont fit the rx plug deal.. i have this rx
http://www3.towerhobbies.com/cgi-bin...?&I=LXJM12&P=7
steering is channel 1 esc is channel to
this heat sink
http://www3.towerhobbies.com/cgi-bin...&I=LXNDP1&P=ML
how do i get a diff adapter?
this heat sink
RE: motor heatsink/fan for rustler
Hi Traxxas4fun ,
can you send me a picture of how it looks mounted on yours? I cannot picture how it fits..
I have an EZRUN 6000kv motor in mine and I also have the wheelie bar.. So I am not sure if this will fit?
by the way the EZRun 60A Esc + 6000kv 5.5T brushless motor kit is insane! in this truck..
Thanks!
Thanks!
TX
I have that exact same Integy heatsink/fan. I simply plugged the fan into my rx, into a spare channel slot ("Battery" or whatever). it plugs in just fine, to the + and - pins. Just make sure if it's getting stuck that the shape of the red plug isn't causing it, in which case, shave a little bit of the bumpy side until it fins into the rx slot freely.
TX
As long as the motor doesn't have that weird finned can, you can clamp the heatsink over the motor, or depending on your motor wires sticking out a certain way, slide the heatsink in from one side. If you clamp it on, it takes a little bit of force, but it works.
