custom chassis in the making!
RE: custom chassis in the making!
ORIGINAL: crushgear64
there does seem to be a bit of flex. no sure if i will be a problem.
Ray
I'm guessing your motor is running in reverse timing beings you switched the motor around. When you flip a tranny, you have to set up your motor for it to run forward and not backwards even though you truck is going forward... does that make sense at all?
Ray
Ray
MT
does it weigh more than stock? That'd heat it up, and like Zero369 said, if your motor had been broken in in the other direction it might heat up more...but for brushless I'm not sure.
#31
Oh, its brushless? Hmmm, plot thickens lol.
I know with brushed motors, you have turn the end bell 180 degrees to get a neutral timing so it can work like normal.
Ray
Ray
#33
ill reprogram it with the motor revesred and see.
edit: well it wouldnt let me, i changed the timing down to 5 and it stays nice and cool.
Ray
#34
i think i lost about 1mph.
maybe gained a tad bit of torque.
i can get this thing to wheelie with an extended reverse tranny without over tightening the slipper and changing the shocks to realy hard. that surprises me.
#39
the chassis snapped and a piece of it is missing.
ruined bulkhead.
ruined top chassis.
ruined bellcrank posts + bent/missing screws.
ruined top chassis support +bent/missing screws.
and a bent suspension pin.
getting a 3mm alloy plate soon to replace it with.
ruined bulkhead.
ruined top chassis.
#41
ORIGINAL: Brainanator
stay away from them curbs! lol
Ray
#42
ORIGINAL: Zero369
No no no Brian, don't you know the curbs hit you; you don't hit the curbs?! That's what always happened to me anyways, I would be driving then all of a sudden a curb would reach and hit me LOL.
Ray
Ray
yea i was just cruising down the completely isolated un curbed road when suddenly a curb dropped out of mid air right in front of the car
#43
ORIGINAL: Zero369
Ray
Ray
Ray
