Tamiya Boomerang 2.2 wheels
Will these wheels work front & rear for a Boomerang with the 12mm hex adapters?
wheels
http://www3.towerhobbies.com/cgi-bin...2&I=LXMX91&P=K
hex adapter
http://www3.towerhobbies.com/cgi-bin...2&I=LXGE28&P=K
If not what other 2.2 wheels will work?
I will use the stock wheels off road, but want 2.2 wheels for onroad.
wheels
hex adapter
IL
RE: Tamiya Boomerang 2.2 wheels
They do use 12mm hexes, so they'd probably fit. They're from the hpi super rs4, which was a 1/8 sedan. I think that the only tires that will fit those rims are one made for the super rs4, it doesn't use standard 2.2 tires.
If you wanted 2.2 truck size onroad tires you might consider...
http://www3.towerhobbies.com/cgi-bin...?&I=LXFBV7&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXM973&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXM974&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXDT97&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXLN12&P=7
All 2.2 truck wheels will fit these tires.
2.2 onroad buggy tires are harder to find. The closest thing is the proline dirt hawg
http://www3.towerhobbies.com/cgi-bin...&I=LXDU13&P=ML
http://www3.towerhobbies.com/cgi-bin...?&I=LXDU14&P=7
Thanks Mad Modder,
I wasn't aware the Super rs4 wheels were not standard 2.2 wheels.
I like the HPI V-Groove tires
