RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
I need help with my HPI E-FIRESTORM
Old 03-01-2010, 09:26 PM
dannybear
Default I need help with my HPI E-FIRESTORM
I have a HPI E-Firestorm 10T RTR 1/10 Electric Truck 2 WD. I would charge my batters and put in the and it would run slow. So I got 2 new batters and the same thang. I thought my charger was bad put I tested it and it looks like it is working. The charger is about 1 year old it is a Piranha Digital peak charger. The first batters is a venom 1800 nicd 7.2 that is about 1year old charged about 35 times.The setting for the chargerI have is nicd 1800mah 3.0 A 10mV/C. The other batters are venom 3000 nimh 7.2 charged 1 time. The charger setting for it is nimh 3000mAh 3.0 A 10m V/C.When I run the car with antenna up not touching anything it will go about 15 feet then it starts jerking and stops.What do you thank it can be? Thanks
Old 03-01-2010, 09:35 PM
Willystylz
Willystylz's Avatar
Default RE: I need help with my HPI E-FIRESTORM
how slow are you talking?
also you say the truck is moving by itself without touching anything? First thing I would make sure of is that your throttle trim is set properly. The truck shouldn't move when you turn it on and aren't touching anything.
suburban_hooligan
suburban_hooligan's Avatar
check the throttle settings on the radio, check the battery's in the radio.  check and maybe re-program the ESC, check the battery connector on the ESC.  clean the motor and check the brushes, make sure they are not hung up or damaged and that they are making good contact with the arm inside the motor
Old 03-01-2010, 09:46 PM
dannybear
Willystylz
It is like it is in cruse mode.
When I run it wide open it go about 15' and starts tojerking and stops.
Old 03-01-2010, 09:48 PM
dannybear
Willystylz
Old 03-01-2010, 09:53 PM
Willystylz
Willystylz's Avatar
so your throttle trim is set correctly and the esc setup proper? is your radio antenna all the way up and not damaged, as well as your receiver antenna?
Old 03-01-2010, 09:55 PM
dannybear
suburban_hooligan
throttle settings is good.
radio has new batters
connectors on the ESC is good
I have not looked at the motor yet.But when I pick up the back end and hold the throttle open it speends good.
Old 03-01-2010, 10:02 PM
dannybear
Throttle trim is set correctly
esc is the charger? If so it is set right..
antenna isall the way up and it is not damaged
What would I look for to see if the receiver antenna is not good?
Old 03-01-2010, 10:07 PM
Willystylz
Willystylz's Avatar
esc is the speed control. for the receiver antenna, just look for any cracks or tears. also is the receiver antenna (wire) pulled all the way up it's sleeve and hanging out the end a few inches?
suburban_hooligan
im betting you've got a brush that's hung up and probably arcing.  iv had that cause short range and "glitching" issues in the past
Old 03-01-2010, 10:10 PM
Willystylz
Willystylz's Avatar
i don't believe the stock motor in that truck is rebuildable
may need a new motor if everything else checks out. Also might be worth reseating the crystal in the receiver and make sure it's sitting snug.
Old 03-01-2010, 10:16 PM
suburban_hooligan
if his charger and 1800 nicd are about a year old, im betting the truck is about a year old.  might be time to replace that motor
Old 03-01-2010, 10:32 PM
dannybear
Ok look at it right now
I dont see cracks on theesc. How do you re-program it?
receiver antenna has no cracks or tears
Itis pulled all the way up it's sleeve and hanging out the end withabout a inche or 2
Old 03-01-2010, 10:36 PM
dannybear
The truck is about 1 year. It is all stock. How would I test the motor with a tester?
Old 03-01-2010, 10:39 PM
rclugnut10
rclugnut10's Avatar
its not, also your batteries since they're old and haven't been run, run them a few times, and see if they wake up it should take a few cycles, it happened to me today i want to FL for vaca for a week or so, came back charged up my ep 4200 and had pretty similar preformance, then came in charged it up again, when back out same setup, and it ran great
the lug
Old 03-01-2010, 10:42 PM
dannybear
On the motor it has a slot on it you can look in. I am looking in it and looks like as I turn the moter it look pitted.
Old 03-01-2010, 10:45 PM
dannybear
I have 2 new batters and it is the same thing
Old 03-01-2010, 10:46 PM
Willystylz
Willystylz's Avatar
When you are charging your new nimhs, they should be warm when fully charged. It is possible your peak charger is sensing an early peak and shutting off prematurely. It used to happen to me with new nimhs. It is possible your new nimhs aren't fully awake yet.
Old 03-01-2010, 10:53 PM
dannybear
So how do I wake them up? Use a alarm clock. Just traying to put sum fun into it. I have been traying to fig this out for 1 mouth.
When I use all my batters I get the same speed out of my car. I am new to all this so I thank you now for your help.
Old 03-01-2010, 10:56 PM
Willystylz
Willystylz's Avatar
Did you get much use out of the truck before this started happening? If so, it is quite possible the motor is worn out.
Old 03-01-2010, 11:05 PM
dannybear
I say about 20 times. Wife is saying about 10 times.Thanking about it befor this started I whent through water.The brushes lookspitted.
Old 03-01-2010, 11:12 PM
dannybear
should the motor be stiff to turn
Old 03-01-2010, 11:23 PM
Willystylz
Willystylz's Avatar
a little bit, but should turn very easily. No real way to test that motor as far as I know. But may be worth getting a new motor.
You say you went through water? I hope the esc or the receiver didn't get wet. That could be your problem right there.
Old 03-01-2010, 11:33 PM
macksara
Sounds like the motor. Carefully touch the motor leads to the battery. Do not let the leads touch each other. The motor should spin fast and make a smooth whining sound. If it sounds rough or glitchy it is worn out. they are $14 at Tower Hobbies. That is real cheap for a motor. Sounds like you got its life out of it at 20 runs. Be sure to break in new motors for longer life.
Old 03-02-2010, 06:21 PM
dannybear
macksara
what is a good motor to get? How do you break in new motors for longer life?
