phoenix sim TX default controls for DX5e
The default setting for the Spektrum DX5e transmitter on my Phoenix sim is reversing the ailerons/ch. 2 such that if I move my stick to bank Left, it banks right and vice versa. My default switches on the Spektrum DX5e are all set to "normal". I've done the setup/calibration countless times but still have the same problem. Any ideas?
My Feedback: (9)
NC
I looked at my transmitter (DX5e) that came with the sim and all channels are set to normal except the ailerons. It is the only one that is reversed. It has been like this since new and have only had to calibrate one time (when installed).
Make sure everything is set to norm except the ailerons. Do this with the TX off and unhooked from the USB cord. Once you have done that; go back through the set up process and see if that fixes the problem.
My Feedback: (17)
IL
vascoboy, From the main Phoenix screen I believe you need to select System>YourControls> ...
Then Select your Tx model then Select Edit profile. On this Edit Profile screen find the column labeled 'invert'... Find your aileron channel (Look for Controller channel #2 below) and put a check in the 'invert' column to reverse the aileron controls... Click Finished to save your changes. I think you will be good to go...
