Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 REFLEX , no contact :( >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 03-14-2004 | 09:41 AM
Default REFLEX , no contact :(
Hi all ,
I am trying to contact Wolfgang from reflex flight simulators , Ive seen him on here on many posts and he seems to be very helpful and a very nice guy to deal with.Is there a problem with the contact emails from his web page... I purchased reflex recently and need to ask him some questions about the software and also about distribution in Australia.
If you are out there Wolfgang please reply to this post and how I can contact you.
Cheers
Jesse ( Kenthurst NSW , Australia)
Old 03-14-2004 | 02:23 PM
wsn
Default RE: REFLEX , no contact :(
Available but overloaded with update work ... For Australia pls contact www.speedlineinternational.com.au. Cheers - wolfgang
Old 03-15-2004 | 07:32 AM
Cheers ,
Thanks Wolfgang.. I was pretty sure you would be flat out working away. Thanks for the tip I will contact them about distribution and my other questions...
Also if anyone knows , do you need to have the radio turned on or does the usb supply power to the radio when using reflex? or do you need to charge up everytime you use it?
Thanks kindly in advance ...
Jesse
Old 03-15-2004 | 09:32 AM
You shoudn't need to turn on the radio if you have the proper connection on the trainer plug. The radio will turn on automatically with the rf module disabled in trainer mode once the plug is pushed in. You will still need to power it using the batteries since the Reflex USB cable does not supply power to the radio. However, with the rf module disables, the radio uses much less energy and should last between 2 to 3 time as long. I've upgraded my 9CHP to 1850mah Nimah batteries and if I just use it on Reflex, the batteries will last between 15 - 16 hours.
