Aero Fly Deluxe - New Version
#528
On the subject of frame rates, I cranked it upto 1600x1200 everything turned up, and I am getting approx 180 fps!!! on my Nvidia 6800
Andy
Andy
#529
QUESTION: This is for Dion or anyone else you could answer: I am interested in running AFP on my Front Projection monitor - it is an 8 foot wide screen by 4 1/2 foot tall. I need to run a custom resolution of either 1280 x 720; 1920x 1080i; or 1368x 768. Basically a widescreen 16:9 aspect ratio. I need to know if AFPD will take "custom resolutions" . A lot of the new games do indeed support 16:9 ratio resolutions from the pc. I am hoping to use one of these resolutions on my pc to drive my projector. A lot of people that have Home theater PC's use a program called "PowerStrip" to create these resolutions if there card doesn't support them natively. Any help to test these resolutions with AFPD would be appreciated. Keep in mind - that on your square shped monitors 4:3 aspect ratio - if AFPD does run - the picture will look squished - but if the game syncs to these reses - then that Is GREAT ! I hope that it does work - I would love to fly on my BIG screen. Thanks in Advance.
#531
I am trying to modify the Yak 55 that I downloaded to be similar to the specifications of the Extreme Flight Yak 54. When I do a "save as" the paint scheme goes to white....no paint scheme at all. Does anyone know how I avoid losing the paint?
Thanks in advance.
Thanks in advance.
#536
SC
Just purchased the Aerofly Professional Deluxe along with an adapter for my Futaba 9C. The simulator is great, however, I am having a problem when I go to edit a model and use the "Save as". The program crashes and I have to restart. If I just use the "Save" I have no problems. Ikarus tech support has no idea and has stopped responding to my e-mails. Typical, they got my $$ and now theyr'e off and running! I've already downloaded the latest video drivers for my 128 mg GForce video card and the latest Direct X drivers from MS.
#538
SC
Yes - I have installed the patches and made sure my Windows xp was up-to-date along with my video drivers and the Directx drivers. I have a 1.4cpu with a 40gig hd and a Gforce 5200 with 128mg video, so I know my pc can run this. Like I said, I can do a "save" with no problem, but if I try to rename a model or do a "save as" the program crashes and I need to restart it.
Aaaaah good old Norton's seems to have been the problem. Although I'm really not sure because I did a reinstall of the Windows xp os. However, disabling Norton's Firewall and Anti Virus software seems to have cleared up the problem. Thanks all for the support.
