Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Quick G3 / G2 question, please. >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 07-12-2005 | 05:16 PM
FiveO's Avatar
Default Quick G3 / G2 question, please.
I am going to get either G2 or 3 and was wondering if you can install on 2 PCs (My desktop and my laptop) or does it limit the installs?
Also what are the problems with ordering G2 used? I understand that G3 is user registered and not registerable unless transferred (right?). Is that the same for G2?
Thanks!
Old 07-12-2005 | 05:43 PM
Default RE: Quick G3 / G2 question, please.
You can install G3 on as many computers as you want. You can only play G3 if you have the G3 interlink plugged in, but there is no check to see whether the G3 disc is inserted.
As for transferring registration, our tech support team can do that. Give them a call when you're ready to buy. http://www.realflight.com/techsupport.html
Old 07-12-2005 | 06:12 PM
FiveO's Avatar
Thanks very much!
I may grab a used copy of G2 as I am concerned my PCs may not run G3 as well.
Does G2 need to be tranferred as well?
Old 07-12-2005 | 07:03 PM
FiveO,
You will need to transfer the registration in order to download the updates to G2 .. and you will need them.
Carl
Old 07-12-2005 | 10:00 PM
FiveO's Avatar
Thanks, I will insure the seller has all of the numbers!
