Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 E-Flite Tensor for AFPD >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 08-12-2005 | 09:19 AM
Default RE: E-Flite Tensor for AFPD
ORIGINAL: STLPilot
I flew your's Ian ... I don't have one ... so I don't know which is better. I'll take your word for it.
But one thing I can point out ... on some of these plane you have to make weight shift laterally to get them to fall out of hover. With the Tensor it will lock into hover with just elevator. But if you put a little bit of weight on one of the wings more then the other ... it will fall out naturally.
I think you can adjust the "mass" of the wings very finely in the TMD file.
Greg.
Old 08-12-2005 | 11:27 AM
Ian.W's Avatar
The tensor is super stable in the hover, its a dab of elevator here, a dab of rudder there, its really effortless. As i said, it just needs much more KE lift and it would be nye-on perfect...for AFP, non D that is...
Old 08-12-2005 | 12:25 PM
My Feedback: (21)
Well you can add side lift to the parameters ... did you know that?
Old 08-12-2005 | 12:39 PM
See attached!
You can adjust it to whatever you want in the TMD file!
Greg.
Old 08-12-2005 | 01:42 PM
Ian.W's Avatar
i know you can adjust it, but i dont know the code in the TMD. What is it??
Ian
Old 08-12-2005 | 01:50 PM
  #31
cd Fuselage/
X = tmvector4r( 1.0000, 0.0000, 0.0000, 0 )
Y = tmvector4r( 0.0000, 1.0000, 0.0000, 0 )
Z = tmvector4r( 0.0000, 0.0000, 1.0000, 0 )
R = tmvector4r( -0.0119, 0.0008, 0.0633, 1 )
Geometry( "~Geometry/Fuselage/" )
Mass = 0.04536
RangeMassMax = 0.5
RangeMassMin = 0.025
Inertia = { 0.0006, 0.0000, 0.0000, 0.0000, 0.0000, 0.0005, -0.0000, 0.0000, 0.0000, -0.0000, 0.0007, 0.0000, 0.0000, 0.0000, 0.0000, 214.0990 }
Kn = 1000
Dn = 20
Dv = 0.05
AreaCenter = tmvector4r( 0.0000, 0.0000, 0.0000, 1 )
CG = tmvector4r( 0.0210, 0.0000, 0.0130, 1 )
SmokeR = tmvector4r( 0.0000, 0.0000, 0.0000, 1 )
Cdx = 2
Cly = 5<<<<<<<<<<<<&l t;<<<<<<
Cdy = 2
Clz = 0.5
Cdz = 2
InertiaScale = 0
cd ../
NP
Greg.
Old 08-12-2005 | 01:51 PM
  #32
Ian.W's Avatar
riiiiiight! ill give it a try!...............trying............yay got it!
Old 08-12-2005 | 02:22 PM
  #33
Ian.W's Avatar
ive had a try with lots of differet setting and ive found that there is a side effect of increasing KE lift that the rudder becomes less and less efective untill the point where at 100 on the lift the rudder, even at 60 degrees and 100 propwash its totally useless. ive found 5 KE lift and 60 degrees rudder + 100 propwash is a good balance
Ian
Old 08-12-2005 | 04:27 PM
  #34
Soooo better or same???
