Real Flight G2 and Windows XP
Is the Great Planes Real Flight G2 simulator compatible with Windows XP?? I purchased it back a few years ago and have not used it since I upgraded my computer to Windows XP, and I wanted to use the simulator again, but I am not sure if it will work with my new operating system.
Mike.
Mike.
ORIGINAL: stang
Mine does. You shouldn't have any problems.
ORIGINAL: RC_Fanatic
Mine did not and their tech support says it will not. I just wonder now if it will run in 98-compatibility mode. The problem I had was that the simple 4-channel inputs would work but nothing else would. I could fly fixed wing (as long as it did not have retracts!) but the heli would not. Radio is a Futaba 8UAFS
ORIGINAL: stang
VA
I started with the original Real Flight then upgraded to the G2 version. Everything worked great. I run Windows XP and used the parallel interface. I also upgraded my graphics card to a much faster game card with 256k memory on the card with no problems. I have now upgraded to the G3 verison.
RayT
RayT
TX
I have been running G2 with add-on's 1, 2, and 3 for about 3 or 4 years now on XP Pro with no problems. I did have to use the "special" install start routine to get it to start on the install. Other than that, no problems.
I also got the gameport to USB converter from RadioShack ($6.97). I use the #2 setting on the converter and it works like a champ !
CJ
CJ
