RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Esky with G4
Old 10-22-2008 | 12:47 AM
Default Esky with G4
Has anybody gotten the Esky 6 channel controller that comes with their helicopters to work with RealFlight G4? I was able to get the Esky controller that comes with fms to work with g4 using an emulator that I found. Using that same emulator, G4 recognizes the Esky 6 channel, but I can't get it to calibrate good. For example, the sticks will not center, and when you go to up the throttle the ailerons move as well. It seems to be seeing the throttle and ailerons as the same axis/channel. If anybody has tried this and gotten it to work or fixed a similar problem, let me know. Thanks.
