Help with Futaba 6ex 2.4G / FMS
HI all,
I just received a GWS GWFSM002 usb lead for my tx to use with FMS but when I try to calibrate it in control panel the crosshairs won`t stay still long enough for me to set left/right etc.
Any ideas as it`s driving me mad!
Cheersants.
Cheersants.
RE: Help with Futaba 6ex 2.4G / FMS
When you calibrate the yokes, just move them from limit to limit. up, down, right, left. Both sticks. After you do this about two or three times for each axis it should be good.
Hi and thanks,
When I try to calibrate in control panel or in FMS I have no left/down movement, it`s as if someone else was pushing constant left/down to thier extremes.
I`ve noticed as well that if I "play" with the cable the connection is not constant, so could it be faulty connection with my Tx or the cable?
ants.
ants.
