Looking for a good 2-stroke oil for smaller Gasoline engine
The SPL is a total synthetic formula, very much unlike the other synthetics out there. Although it will not produce carbon, you may see an increase in carbon residue on your plane because this lubricant has the unique property of breaking up built up deposits and cleaning out the combustion chamber, ring lands and piston top.
Also remember that you will always have some residue since gasoline does not burn clean.
As Brian (flyinwalenda) points out, always use the mixture ratio that the engine manufacturer recommends.
I hope this helps
I hope this helps
CO
There are a large number of quality 2-stroke oils, just be sure to use an oil that is designed for air cooled engines (API TC or JASO FD ratings) , don't use an oil with a TC-W3 rating, those are for water cooled 2 strokes.
I have used many brands of 2 stroke oils that I would feel comfortable using in most anything, some of them include but are not limited to, in no particular order.
Lawn Boy (not synthetic)
Ace Hardware (synthetic blend)
Stihl HP ultra (full synthetic, currently using this)
Craftsman full synthetic
Bel Ray (something - full synthetic)
Amsoil Dominator (Full Synthetic)
Mobil1 2T (I used this for years but have not seen any in a few years)
Evolution Engines (blue 2-stroke oil)
Then there is all the no-name stuff I used because it was on sale at the small engine shop for $0.79 a bottle, I found it difficult to go wrong with most any modern 2-stroke oil as long as you stay within the engine manufacturers guidelines.
#31
I can't help you with the Amsoil question.
Personally, I'd use Castrol PowerRS 2Stroke (in some countries Castrol TTS).
I get superb results with it, and it is cheap if you know where to get it.
#33
You're guaranteed to like it. In bulk it should be approx 7 bucks per quart, and at that price, never mind the bulk purchase, your clubmates will take it from your hands like there's no tomorrow.
I typically buy in boxes of 12, but have never managed to finish more than 3 bottles from a box (and I mix 10:1...).
