RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
DIY 1/4 CARS RCMK 600B
Old 04-17-2013, 12:25 AM
splcrazy
Default RE: DIY 1/4 CARS RCMK 600B
LMFAO now it makes sense it really does look like a baja chrysler 300 station wagon
Old 04-18-2013, 02:35 AM
FIDRC2012
THE losi 5ive-t and FID 4WD and hpi baja 5b ss
Old 04-18-2013, 06:07 AM
mooman007uk
mooman007uk's Avatar
what are you doing for pipes?
Old 06-24-2013, 12:50 AM
FIDRC2012
RCMK 600B
Old 06-24-2013, 01:29 AM
splcrazy
looks awesome .
Old 06-24-2013, 07:13 AM
  #31
GT100
The dual tank set up might be a bad idea. If by chance, one of your tanks runs out before the other, you'll be running one of the cylinders dry. Might cause scaring of the walls of the cylinder or even cease. That was something I'd considered when building my rig and was quickly told not to by my engine guy.
Old 06-24-2013, 09:30 AM
  #32
CEN USA
CEN USA's Avatar
Very nice set up and killer prototype work!!
Old 06-24-2013, 09:34 AM
  #33
The Real Dogman
The Real Dogman's Avatar
I agree! That was the first thing that I thought of
but if they had a nice big open transfer tube, they might get away with it. The current packaging does not look like it's condusive to a single tank or a big transfer tube. Too bad.
ORIGINAL: GT100
Old 06-24-2013, 12:49 PM
  #34
wan6176
well setup.dun bother abt other crap opinion...keep on going..
Old 06-24-2013, 06:09 PM
  #35
DarkFire989
DarkFire989's Avatar
That roll cage has to go.
Old 08-12-2013, 09:07 PM
  #36
FIDRC2012
NEW engine for this car
ID:	1907569   Click image for larger version
ID:	1907570   Click image for larger version
ID:	1907571   Click image for larger version
ID:	1907572   Click image for larger version
Old 08-16-2013, 08:31 PM
  #37
FIDRC2012
Old 08-16-2013, 09:41 PM
  #38
CEN USA
CEN USA's Avatar
That's hott!
Old 08-17-2013, 06:20 PM
  #39
Straick
I know it doesn't look condusive to using a single tank, but give it a shot. If you just tee the fuel supply lines together and the tank returns together, you might be able to get away with it, especially seeing as these carbs will pump quite a bit more fuel than they will feed into the engine.
Any ideas as to where you'll put the radiator or some form of reservoir/expansion tank? Maybe, if you could run it off one fuel tank, then you could put it where the second tank is.
I do like the idea of using a computer radiator for this. Never had thought of that as an application for them. My only question on it, are you using a true radiator design, or one of the cheaper ones that is just a long piece of tubing bent back and forth with fins on it?
P.S. When do you think that you could get a video of it running? I'd LOVE to hear that twin engine.
Old 08-18-2013, 01:27 PM
  #40
mooman007uk
i'm running a twin with a single tank line to feed both carbs, i just made sure the line into the tank is more than twice the area (the bore) than the carb inlet nipple bores so it'll flowmore than required by both carbs, i then tee'd off that with smaller diameter tube to each carb
returns are slightly bigger than nipple bore, run to a common return on a "y" not had any lean issues
Old 09-06-2013, 11:43 AM
  #41
Whozenext
Hello,
Any update for this project?
Cheers.
Whoz.
Old 05-11-2022, 01:05 AM
  #42
fidracing
fidracing's Avatar
shame this is not completed. let me finish this post. please wait.
