servos for large scale offroad quad
CA
working on a home project and was wondering what are the servos and receivers out there that can do the job. project is going to be like an atv size offroader.
thanks
thanks
PA
RE: servos for large scale offroad quad
You say its going to be atv size? Do you mean like a full size atv? What kind of weight are you thinking this will be? Is it going to be totally custom built, or something built off of a regular atv?
For a full size atv you are going to need a huge steering and brake servo. I've seen somebody make servos out of automobile window motors, but i'm not sure how easy that is to set up or how well it works out.
CA
it's going to be a custom job. the frame and everything. using a lawn mower engine. about the size of an atv but a lot lighter. wheels are going to be from a smaller ATV. i usually built smaller scale like 1/8 trucks but this is my dream project. trying to find the things i need and then built the frame around what i have. so far from the engine size frame looks like it will about the size of a small atv when comlete with tires.
thanks guys for any input and tips.
CA
checkout the tone servos...looks like they will be just the servos for the job, thanks, plus they have futaba plugs. already have a futaba radio so thats a plus...
CA
when you guys mention "Tone" servos, are you referring to "Tonegawa" Servos like this:
http://www.hobbyclub.com/tonegawa-indservos.htm
or do you mean something else?
