Question about 1/5 gear pitch?
Okay, I know someone on here will know the answer to this question... especially you guys across the pond....
I need a larger spur (halfshaft) gear for my drag car than is available from FG. The largest spur currently available is a 48 tooth for the MT truck.
What is the "pitch" of the FG gears?
To the best I can figure, I believe they are a metric Module 1.5, as I have found very similar gears in the Stock Drive Products catalog, and they go all the way to 100 teeth.
Is this correct and compatible with the line of FG pinions?
RE: Question about 1/5 gear pitch?
All FG gears are metric module 1.5, so they are compatible.
You can also try
American Metric® Corporation
52 Metric Road, Laurens, SC 29360
Phone (864) 876-2011
Fax: (864) 876-2630
Email: [email protected]
You can also try
Fax: (864) 876-2630
