FG pajero body help
FG pajero body help
hey all
i need some help my stock fg marder bugy body is on its way out and has a hard lifeand having 2 cut out a large area for the samba pipe dosent hel the overall strength. Anyway im thnking of a pajero coversion kit with the under tray but i have a few questions.
1. will my samba pipe still fit now that the role cage has gone and there is an undertray there
2. is the body going to breck up in a role beccuse theres no rolecage
3. will i still be able to put MT tires on it
4.is it true that the wheels can rub the wheel arches when the suspension is fully depressed or turnning
5 what and where do the cooling holes in the body need to be cut(this is important for me becuse 1 of the resons i want the body is becuse of the enormas amount of protection it gives for diff gears electronics servos ect.
thnks any sort of help is appresiated
RE: FG pajero body help
oh here are some pictures just click 2 enlarge them thnks
[link=http://www.hobbycenter-france.com/dossiers/fg_pajero/index.shtml]http://www.hobbycenter-france.com/dossiers/fg_pajero/index.shtml[/link]
My friend has the FG Pajero its huge makes the MT look smallish, he bashes the s**t out of it and it takes it. He did split the body a little on the side mounts but has since made a full steel roll cage which stopped this when rolling.
MT tyres wont fit unless you cut the shell and under tray to bits
You still use the roll bar.
If you look back through my posts in this section, you will see a pic of mine somewhere.
They sound like a vibrating bucket when run, but do look the nuts.
To start and stop the engine, you need to remoove the shell each time
But they do look good when painted and stickerd up
Good luck
Good luck
thnks leeG i was wanting it for protection of electronicts and being able to have room to do twin exust but i dont want something that sounds like a bucket and that i can have MT tires on without losing thta protection ill have to think about which body to go for
thnks again im looking 4 the thread now
Just an idea to reduce the bee in a bucket noise. get some 10mm or similar sound proofing foam and stick it around the inside of the body to reduce vibration. the only drawback would be a small increase in the centre of gravity.
