Kill Swich
Kill Swich
Guys im not sure if its called kill swich or what anyways im talking about the yellow botton that shuts of the engine i have a problem with mine the botton keeps sticking in and i have to try to get it out each and every time and upgraded one or a sulotion
RE: Kill Swich
get a small self tapping screw and screw it into the plastic button. this gives you something to grip when pulling the button out if it gets stuck.
RE: Kill Swich
jimbo
is right if you go to www.fgperformancerc.com and check the tips, and tricks button the fix that jimbo mentioned is there with full blown instructions
RE: Kill Swich
That's probably where I got the idea from. Either that or on here some where.
When I joined I went back and read every thread there was. I found some great info and ideas.
PA
RE: Kill Swich
I've never had this problem, but if i did i'd probably take the button out of the car, and wrap it in a balloon, then reinstall it. This way dirt cant enter it and cause it to get stuck.
