Help me for servo...
Hello guys!!Which servo control can I mount on my fg monstertruck?One hitech maxi HS 805 bb+ or two hitech?So please help my[sm=drowning.gif][sm=crying.gif]
Thank you for your answer.....
Excuse my for my english but i am an Italian boy.[sm=biggrin.gif]
RE: Help me for servo...
805 is torquey enough, but it's nylon geared. I went for dual 705MG which are lower in torque, but with two greater total amount- are are metal gear. You can fit two quarter scale servos for steering in the standard "Marder" RC plate.
Try and use servos that have metal gear.
What radio do you have? If you have HRS system you MUST use digital servos. If you have FM/FM PCM you can use analogue or digital servos (and mix and match)
Banned
CA
1 hs 805 or 2 705 or 2 755 hb. Nylon gear servos are fine. It's what you want to pay to play. Stay away from the Hs5745mg servo under rated and too many horror stories.
The HiTec 5745 is reliable if your end points are adjusted correctly. They overheat otherwise.
It is supposed to be the same servo as the Multiplex Rhino which has become a firm favourite.
tonegawa great servo is you have spare £200 - otherwise hitec 5745mg are very good servos pushing 18kg of torque,just like any if there not setup correct they will over heat and burnout.
Thanks for the answers...I will use two hitec 755 hb for my fg monster.And for the throttle servo,which?Futaba s3010???is ok?
