K&N Airfilter
K&N Airfilter
cananyone give me a item number/or a place in california that as the right kn airfilter. it will fit on a marder and mt right. do i need anything more?
ty tom
ty tom
RE: K&N Airfilter
Just my advice, if you are going to drive in dusty places, sand, mud etc, stay away from the k&n paper filters, the foam is much better.
WA
RE: K&N Airfilter
Didnt you have major problems with you motor before because of filtration probs?
Use the stock FG filter! and water repelent cover..
K&N is a nice look but not for RC..
NY
RE: K&N Airfilter
I have to add to the mix, and agree with the others, the K&N filter is not good for dusty, dirt track running.
I had one in my MT for 2 tanks with an outer wear over it. I still had dust stuck to the oil inside the filter. It is obvious that some of it got into the mill as well. I have now gone back to the stock foam filter.
MI
RE: K&N Airfilter
They are right. K&N suck in the dust like a hoover. They are cotton gauze not paper by the way. I learned my lesson with these filters on the Jeep you see under my name. I had $10,000 in upgrades to crawl and off road this thing and a stinking K&N took some life off the motor. That Jeep filter was 4 foot from the groun these cars we run are right at ground level where the dust is comming from. Hell, K&N even sells a FOAM prefilter of there own for dusty running because they know it eats dirt.
RE: K&N Airfilter
Go all out and buy a Pitstop tuning filter mate, it has all the performance gain of the K&N but its a 2 stage foam filter
im about to get one as im sick of my K&N
about the same price as the K&N too i think
Monstrous
Monstrous
RE: K&N Airfilter
I was running the K&N on my MB with a pre filter, and even with the pre filter it was getting dirt into the carb! Dont get one!! Bad, Bad, Bad.....[:@]
WA
RE: K&N Airfilter
you could always use a stock, dual air filter, for the firhammer....... they work really good
http://www2.towerhobbies.com/cgi-bin...?&I=LXHTX0&P=Z
http://www2.towerhobbies.com/cgi-bin...?&I=LXHTW9&P=Z
RE: K&N Airfilter
That filter is good hellya, and it has a blue alloy shell It's very similar to fg's original monster truck filter, but with a blue twist
Here is a link to the makers of the pitstop filter: http://www.pitstop-tuningcenter.nl/ You can order direct from them, or ask for a retailer in the US, good luck [sm=thumbup.gif][sm=biggrin.gif]
