Baja 5B Mods-Lets See Them
#176
CA
RE: Baja 5B Mods-Lets See Them
Hello. I'm new to this particular forum but not to 5th scale. I just picked up a used 5B last night. I have a couple questions and hoped I could get the answers here....
I removed the plastic trans gear cover and noticed that the clutch bell/pinion gear move back and forth about a quarter inch. Is this normal? It doesn't move back and forth like the bearing is smoked but rather in and out towards/away from the engine.
My car is missing the 11mm purple spacer directly under the clutch bell. The hole on the engine is stripped out. I suspect this is an important mounting point on this side of the engine.
Anyone hear about the engine cases breaking on the left side of the car? One of the "spare" engines I received had two broken mounting bosses........
The car came with a Jetpro pipe and the original owner said that the additional leverage and weight of the pipe is what is breaking the cases. That and the stadium size jumps he used to frequent.
I would appreciate any feedback.
Thanks.
Thanks.
#177
ORIGINAL: taildraggerdave
Thanks.
Thanks.
#178
WI
Here is another great product from Brice ARNOLD (B&T CUSTOMS) That I just got in the mail, just thought I would show this info ........ he makes this in billet also
#179
AL
RE: [Awaiting Approval]
OK simple question but just curious. As we all know HPI sends barely enough 2-stroke oil. Got my buggy friday and already a gallon through it. Anyway what oil are people running in this engine and what ratio? Hpi say's 25:1 but i can not find anything for this specific ratio at the usual places. Help please.
#180
I'm using Bel-Ray in a 25:1 ratio, but a lot of people are using 32:1 without problems. After I'm done with my second tank, I'm planning to go to 32:1
ORIGINAL: bigbad1ton
#181
WI
here is another new mod from B & T custom that is comming out....an alloy spark plug protector
avail in diamond plate and in plain ole alloy.. this is the diamond plate... these will be avail @ Python racing http://www.pythonmotorsports.com/fg/fg-modellsport.html
#186
WI
ORIGINAL: bigger the better
GOOD idea, what about a 1piece that would replace the front one?
ORIGINAL: kwakr
or if he made a lip to slot underneath that other piece there....so no dirt or debris gets in....does look neat though....
#191
My Feedback: (34)
ORIGINAL: looney
Would anyone know the length of the reciever arial from circuit board to tip, on the baja. I damaged mine and it's causing me greef. I believe this is my problem with the electrics at the moment.
19 inches for receivers here in the states.
Curt
Cheers
Curt
Cheers
#192
Great list of mods and tips guys!
I finally got things moving.
I ran today with a DDM Dominator pipe. Wow, what a difference over stock. The stock flat low and mid power now comes alive, and the top end is screaming. Very impressed.
The shocks were leaking new out of the box. This was easily remedied with a ".025 shim under the shock shaft 2 o-rings to create the required "squish".
3 minutes into my first run with everything stock before I even installed the pipe, the socket head of the pinion screw broke off and the washer jammed in between the pinion and spur gear. The moment it locked up I shut down to find the problem. Instead of gassing it again and tearing up the gears, I was able to pick the washer out of the gear with no apparent damage. I extracted the broken screw remaining in the output shaft of the clutch bell and re-installed everything with a new higher quality screw and loctite. You guys were not kidding about low quality screws.
Switched over to an Airtronics M8 and a waterproof failsafe from Schumacher.(one of the nicer failsafes available and waterproof to boot!)
Next step will be a reed kit, porting and then milling a window on the intake side of the piston skirt to take full advantage of what the reed valves have to offer.
I would like to try the sound of a silencer on the exhaust, like a dirtbike or quad, but the Dominator`s stinger is too close to the right rear tire to be able to install a silencer. A good silencer creates a deeper and much more pleasant tone. Anyone familiar with MX bikes will know what I mean. Shorty pipes are loud and nasty, full silencers are deep, smooth and powerful. Power can be heard more in tone than in volume.
#193
OR
I don't know if it's just me, but around 1/2 of the pictures posted show the dreaded red X[X(] I've tried using Mozilla and Netscape but then they don't even show up any ideas?[&:]
#194
MD
Hi, what is "stall" when talking about the clutch? If I drill or dremel the shoes willit give better torque? Would I have to drill or remove the same amount from each shoe and if i drill in the same locations?
#196
WI
ORIGINAL: Sparky06
that means the pics are no longer avail what pics are you looking for .and I can get them for you....LMK I have almost all of Brices pics
#200
OR
ORIGINAL: hndaman1
ORIGINAL: Sparky06
