TREVOR SIMPSON CYNDER FOR BAJA
RE: TREVOR SIMPSON CYNDER FOR BAJA
ORIGINAL: kryptonite5b
send u s a link. i love looking at trevor simpson stuff. probly way over priced tho. but damn does it look good
its not over priced because you get what you pay for and TS stuff is TOP QUALITY FULL STOP , i have the TS induction crankcase and its a ripper , the TS head kit has a 40mm skirt width and is ONLY designed and made to fit the TS induction crankcases ONLY , will not fit any other type of engine case, THATS one style of his head kits lol
if your looking to fit a ts head kit onto your existing cy baja5b motor then on DDM they have part number cc320 36mm head kit which is designed to run stock length crank , they have many diferant ts head kits too many for me to mention and they all have differances so you need to read the fine print , if in doubt just send DDM an email about what you want to run on what engine you currantly have in it now and they should as always steer you in the right direction
since your in michigan contact doug at [email protected] he in in the grand rapids area and is a great engine builder he want steer u wrong.
ORIGINAL: part-time
budman, you need to be a bit more patient dude, not everyone is running these high dollar mills.
6-7 hp for a full built up one. The cylinder your asking about requires the cases. I have this set-up and am very happy with it. Spend the money and buld it and you will be more than happy. Word of advice it will TWIST HD Dogbones! This motor will spit your tires out of the beadlocks. Throtlle management is a must on this engine. It has almost uncontrollable power. In a word WICKED!
yeah well when you build a engine 7 to 8 HP PLUS baja5b like i have , be prepared to spend even more money on upgrading the diff to an ss , all tranny gears to hd, alloy gear box , four bolt alloy clutch carrier , pinion and spur gears , plenty of pinion bolts , i got a big load of parts coming in and hope to install them all in this weekend
yeah i will try to get a vid up one day , this baja is driving me nuts and many thousands later hopefully the upgrades to this machine will be finished this weekend and when this project is done im moving onto fully upgrading my savage x 4.6 and my jato3.3 , im planning to install the savage 5.9 motor into my jato3.3 lol its gonna be insane lol
Banned
Wow it looks soo purdy!
Apart from that bit in the middle that looks all crusty, they should do something about that bit.
ORIGINAL: Lunar Wolf
<melody> "This is a man's world..."</melody>...
i also fancy this engine but not yet . ill wait until i blown my 26 feully . im thingking instead of puting the ts headkit is put the sikk and ds head kit on it plus a 813 carb? is that possible?
thats the TS engine crankcases im using , if you's are gonna build one dont forget to make it a stuffed crank and dont forget to install the HRS zero drag seals , its the most power your ever gonna feel from this , and a rear mount DDM pipe , and upgraded tranny , diff and clutch parts , its the most insane package . im going to eventually buy the massive TGN exhaust pipe and see how that goes
ORIGINAL: 9544
Splcrazy, Trevor suggest unstuffed crank. 1mm my engine pulled 6.73 on a dyno with a 668 carb and a TGN pipe
