RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
MCD conversion question!
Old 09-28-2008 | 12:53 PM
Default MCD conversion question!
Hi i might be able to get hold or an MCD monster truck and wondered are they like FGs built around the same chassis as the rest of the models?
The reason i ask is that i have an FG Monster truck and was thinking about getting the MCD baja 1000, but because i can get the MT slightly cheaper i wondered if i wanted i`m not saying i will, but could i convert
to the race runner or baja, or are the parts completely different.
Guy
Old 09-28-2008 | 02:04 PM
Default RE: MCD conversion question!
There would be some parts you would need to change over.
Also you would need to know which model it was before you could order anything.
I am contemplating doing the opposite, going from a Baja to a MT, want the best of both worlds.
Unfortunately the Evo 3 Baja axle shafts are short and do not fit through the MT rims.
It can definitely be done however.
Old 09-28-2008 | 02:11 PM
Hi yeah its the newst model Evo3 with wider wheels or something in that vane.
Guy
Old 09-28-2008 | 06:21 PM
clubin's Avatar
I Bought a Baja 1000 and then I purchased everything I needed to convert it to MT here are the pix.
Here is it after the conversion to MT. Gear ratio change, side plates, tires+rims, body mounts are also different and a servo mounting plate spacer.
The meat and bones of the RR/MT and Baja 1000 are all the same, the bodies mount a little different, and some of the outer shealds are different, the conversion to Baja won't cost you very much.
