King Motor Baja Flywheel and Clutch
HI
The pull-start screw somehow came loose and tore up five fins on the flywheel. I removed the engine and ordered the parts to replace the flywheel and pull-start. Since I had the engine off, I decided that I will replace the stock clutch with an upgraded clutch - 8000 rpm. I'm sort of new to 1/5 scale, and need some advise on how to remove the flywheel and clutch. Do I need any special tools etc? Appreciate anyone's assistance.
