Quick Rampage Air Filter Question
WI
This may be a bit of a silly question, but I was wondering how you get the cap off the stock air filter? It seems like it would just pop off, but I'm not sure if that's how it comes off. It's on there pretty good and I don't wanna crank on it if that's not how it's supposed to come off.
Also, while I'm creating a new thread, will the hpi baja air filter fit on to the rampage without any problems? I do realize that you probably have to remove that bar right in front of the air filter, but aside from that is there any other issues? Will it run into the throttle linkage at all?
AZ
RE: Quick Rampage Air Filter Question
The "cap" does not come off. You squeeze the foam and it will come out the front. When you do that, take the rest off and get an HPI filter. Most of us are using the HPI set-up, by removing the front bar,a nd putting the throttle linkage underneath the servo arm.
