A Stroke Of Genius
A Stroke Of Genius
Ok, so I haven't got a lathe but need to make one end of a rod smaller in diameter than the rest of it.[sm=72_72.gif]
What I do have is a bench grinder and a powerdrill.
Hmmm
Idea.
[sm=idea.gif]
Worked pretty well actually.
That bearing got very hot though....[sm=48_48.gif]
Has anyone got any similar tips or tricks for getting around the lack of equipment in the shed?
Banned
RE: A Stroke Of Genius
With the right tools you can get a professional job. What A square shaft? Have you ever seen a sprocket with a hub before? much easier to work with.
The desperation and lack of tools have made me think like you,DV!I have used a bolt with the same innerdiameter as the thing i had to grind off,fastened it with a nut on the other side,and put this in the powerdrill,and put the powerdrill in a vise.Used a coarse file to start with,and ended up with sandpaper
That is actually good results for the tools you resorted too.
I have a question: How did you know when to stop grinding down? I.e. how did you know you hit the diameter you needed and prevented youself from grinding too much?
Done something similar before... put the job in the drill press, turned it on, and worked the diameter with angle grinder/disc sander!!!
We now call it the "vertical lathe"
You need to get yourself a drill press and a great big bunch of metal files...sooo useful!
safety first that grinder could start at any time.
(Or are you referring to the sign behind it?)
Also a case of "use what you've got"
