Elcon Clutch, Adjustments
GA
RE: Elcon Clutch, Adjustments
This is the one I would get.
http://www.davesmotors.com/s.nl/c.88...t.A/id.2423/.f
AB, CANADA
I have the four shoe teflon one, very similar to the elcon one. Pitstop tuning makes a very nice one to. Kinda pricey to get over here thou.
I am actually surprised when I hit the net that the LB 4shoe Elcon style clutch is just a few cents different than the Elcon clutch! (Like the one 46u just linked)
You are right, these clutches are not cheap, but for their quality and the performance I experienced, they are definitely more than a cut above of the stock clutches.
GA
Turtle racing makes a clutch cover for the HPI Baja might fit others but has a spacer made on it for the Baja you can adjust the clutch by only removing a rubber plug.
