Homemade rc, mounted sprocket finally/sprocket question?
Well i ended up mounting the sprocket to a shaft from parts i had lying around.I got a hex nut,filed away at it until i could press it into the sprocket,drilled the centre of the nut so it could fit on the shaft,then put a small nut and bolt through the nut and shaft.
As you can see both sprockets have a rounded edge to them on the teeth,and i accidently pressed the larger sprocket into the nut the wrong way around,so as you can see in picture number 4,when the smaller sprocket is mounted to the engine,the round edged on the teeth of both sprockets will be facing opposite way.Will this cause the chain to fall off,or doesn't it really matter?
RE: Homemade rc, mounted sprocket finally/sprocket question?
Should be ok.
It takes a bit more than a rounded enge to make a chain come off.
During my experimentations with chains and sprockets at the very beginning of my build I had the sprockets all wonky and out of line and it still worked.
As I was getting everything from the scrapyard they were all mismatched and the chains weren't matched to the sprockets etc.
The sprocket that I had mounted on the clutch was going in the opposite direction that it was designed to, and you know how those bike sprockets have funny angled teeth to enable the chain to slide across when you change gear.
The only time it came off was when one of the bike hubs came loose on the axle and it wobbled around and the chain snapped at the connection link.
I never found the remains of that link either.....
ORIGINAL: naynay12
As you can see both sprockets have a rounded edge to them on the teeth,and i accidentally pressed the larger sprocket into the nut the wrong way around,so as you can see in picture number 4,when the smaller sprocket is mounted to the engine,the round edged on the teeth of both sprockets will be facing opposite way.Will this cause the chain to fall off,or doesn't it really matter?
depends on the direction of rotation, mate.
If you have a sprocket rotating clockwise (looking at the outside of it all - motor in front of the rear wheels - located to the left) you would need a left handed thread. there fore, as the motor turned, under load, the clutch bolt/nut would want to self tighten.
If you had a RH thread here, the bolt/nut would come undone as the motor spins. Same goes for vice versa.
As far as sprocket teeth design, I think you won't see any dramas there.
Good luck!!
Banned
With the right tools you can get the job done faster and more accurate as well as using standard parts off the shelf.
Not all of us have access to the right tools, neither can we afford the right parts off the shelf.
I for one prefer to make things up myself anyway as it's more of a challenge, and feels more like it's your own creation as well.
Nothing like spending a couple of days walking around pondering on how to solve a problem and then all of a sudden it comes to you - you try it and it works.
best feeling ever.
best feeling ever.
yeah yeah 100%
back to original post I agree you should not have an issue with the chain coming off as long as its resonably tight and inline. But I am not sure exactly what you mean about the rounded edge opposite . The smaller gear is rounded to let the chain run smooth around such a small dia sprocket direction should not matter.
Drewcrew6
Drewcrew6
