baja5b rims tyres on FG MT
i know you can change the axles on the FG to put on baja rims on the FG , but do they make a double rim rear axle for the FG so i can put two baja rims on the rear of a FG MT so ill have two rear rims on the rear left and two rims on the right
RE: baja5b rims tyres on FG MT
ORIGINAL: RAMTech-HBF-LSF
Lunatik makes a double Baja axle kit. You would need the FG to Baja adapters first though.
AZ
My bad, the Luntik kit replaces the hex adapter. You won't be able to make it work on the FG. I'm not sure how they work now??
http://www.teamgonads.com/rccars/LunaTik/8925.html
It cant be done , ramtech and ams make adapters for the FG mt so you can fit baja5b rims onto the FG but you can only fit a single rim , the lunatik double rim adapter only fits onto the baja5b round axle shaft with the pin . What we need to be invented is a FG MT double rim adapter for the FG MT to fit double baja5b rims onto a FGMT , it will be a cool idea for whoever wants to make this invention , it would look super cool too .
