Crank down your wheel nuts!
Over the weekend, while it was actually warm, I took out my RC. I was fiddling with the 2speed by adjusting the shift point, so I kept the rear wheel nut loose. Anyways, when running it to see where the shift point was engaging at, the nut worked loose, the ***** end of the RC hit the grass, and the wheel went sailing downfield. Here are some pics of my emparrasing moment.
[youtube]http://www.youtube.com/watch?v=ABFSjNYpyOc[/youtube]
I usually crank down on the wheel nuts, really hard. Even to the point that I have to really torque them hard so that they will never come loose. And this is in addition to loc-tite!
RE: Crank down your wheel nuts!
did you convert that to 4wd? there is only two front springs on each side , i like all the alloy too did it come like that or did you convert it all to alloy . i always check the nuts between runs and keep a spanner socket wrench handy to tighten them everynow and then .
This is the 4wd comp version, it began with only 1 shock per wheel, I took off the rear comp shocks and put on 4 upgrade alum shocks for the non-comp FGs. I like the stiffer feel, but unfortunately, I need to go all 4 rear springs as chrome, the blue ones with the chrome ones make the rear TOO stiff.
