buckshot racing X2R sand runner
#33
RE: buckshot racing X2R sand runner
That looks cool.
Like an angry cat rearing up or something.
Oh, and your deck boards are laid with the wrong side up.... [&:]
#36
CA
you need to adjust your pre load on the shock boots on the rear. a little on the slow side.
you have motivate me to build my own. your project is very sweet. now i need motivation to get some money to do it.
#40
fantastic work mate - I see you marked out on the rear swing arm behind the lwr shock mount. are you cutting that off?
Only was thinking were you going to put a small vertical support between the 2 x flats to support (gusset) the shock mount? (to stop the 2 x swing arm plates flexing under load)?
#41
hi thanks mate, yea once the clearence is sorted for drive shafts i can slide a rib in under mounts and then box the whole rear part of the arm
#42
made the bearing holder today to suport drve pully, now the main shaft has 3 bearing, making the same at the other end to suport spur gear shaft
#43
ORIGINAL: stiggwelder
I like the idea of a 3 bearing shaft..industrial grade!! Love your work, mate[8D][8D][8D][8D][8D][8D][8D][8D][8D]
#45
hi,no the shaft is fixed in the box, goona cut a couple of mm into a square of ally and drill and bolt to hold bearing in
