baja 5b gas
baja 5b gas
i have a question i have been just using the regular octane gas for my baja 5b and was wondering is that the best for it or it i use a higher octane with it make it run better and what is the best octane to go with out risking any damage to the motor thanks
RE: baja 5b gas
I won't even approach the octane wars but what WILL damage and eventually ruin the engine is that crap of a lie ethanol stuff in gas. It will ruin seals and bearings faster in 2 strokes, so if you are able to, get whatever gas in you area that DOES NOT contain ethanol. I drive 10 miles outa town to get 91 octane non-ethanol snowmobile gas in my area.
In short, if your engine is NOT modified/ported/headed, use 87 octane. Use 91 or higher if does have those type of modifications, as long as it doesn't contain that tree hugging, hippy crap, save the earth ethanol shiat.
ON, CANADA
RE: baja 5b gas
i did some research and saw that most premium gasoline does not contain ethanol or contain only small amounts of it...
gonna go to preto canada, shells, and sunco and ask just to make sure if their fuel contain ethanol or not.
freezetron its good that you brough this up.
RE: baja 5b gas
ORIGINAL: mubus
ON, CANADA
RE: baja 5b gas
lol i live in toronto and only the premium doesn't have ethanol because there are many boaters who live here and need gasoline without ethanol for their engines
ON, CANADA
RE: baja 5b gas
plus premium burns cleaner not that it makes a difference
oh and guys do you know how to properly dispose of old gasoline in a form where its legal and i won't get arrested...
lol i came from nitro i just dump old fuel (left overs in the tank) on the side walk and let it dry up:P
AZ
RE: baja 5b gas
lol when we have old fuel, we find a and hill, and pour the gas on it, and let it burn
ORIGINAL: mubus
Moderator
RE: baja 5b gas
I generally use 93 octane in all my large scale stuff. Any pump gas or camp fuel is fine - but like freezetron said, avoid ethanol. Pure gasoline is best. From that day onwards I've only let him drive my 1/18 scale electrics
