RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Salto v-tail (new)
Old 11-20-2011, 03:08 AM
sheko_2000
Default Salto v-tail (new)
hello,
am new with gliders
i used to fly a phonex2000 EP glider 2m wing span from hobbyking and it was so easy for me
now i got myself a Salto V-tail 2.6 wing span from flyfly models
but as we don’t have lots of mountains here in Egypt i managed to convert it to EP with a folding prop
so anyone could help me in setting up my moving surfaces
any special recommendations ?!
- i will mix my elevator with the rudder to make the v-tail work on both functions
- i will also setup my flaps on a 2 position switch (1st) and a butterfly mode on the same switch (2nd)
- any more mixes i should make ??
- what is the max through of ailerons and flaps ??
- how can i properly mount my wings, as the provided parts is a carbon fiber wing joint bar, 2 carbon fiber roads for each wing to point the wing to the fuselage, O ringed head screws with a spring
- so the only part that will hold and keep the wingattachedthe fuselage is that spring between these two screws
is that can provide enough strings to the wing???
i am a gasoline planes RC pilot but with ZERO experience in gliders )
Old 11-20-2011, 07:48 AM
A10FLYR
A10FLYR's Avatar
Default RE: Salto v-tail (new)
Lots of power
Fly it fast
Be careful of tip stall
You might want to use a wheeled dolly for launch as the Salto needs speed to fly.
Everything you have done is OK.
Good luck...
Old 11-20-2011, 08:09 AM
sheko_2000
is installing the curved wing tip to the wing could help in reducing the chances of wing tip stall ??
Old 11-20-2011, 09:10 AM
A10FLYR
A10FLYR's Avatar
That I do not know. It would not hurt to try.
