Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 Help on Throttle Cut setup >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 10-06-2003 | 02:51 AM
Default Help on Throttle Cut setup
Setup the throttle cut using sw H on a futaba 9CHP for a raptor v2 heli. When I activate the throttle cut, the servo will close the throttle and I cannot activate the throttle control until I restart my TX. Is this normal?
Old 10-06-2003 | 10:47 AM
`3D
Default RE: Help on Throttle Cut setup
No it's not normal...is this the sping loaded (trainer) switch?
Everything should go back to normal when the switch is returned to it's normal positon.
Old 10-07-2003 | 10:13 AM
Somehow, if I assign to sw H which is the only ones that springs back, It happens, the only way to engage my throttle again is to hold the H switch down and push the throttle stick beyond the cut point.
When I assigned to other sw it is ok.
Old 10-07-2003 | 01:31 PM
`3D
Not sure whats going on...I have mine on that switch and it works fine [sm=confused.gif]
Old 10-07-2003 | 08:55 PM
You need to go into the the throttle cut settings and put
the throttle stick % to 0. And why your there make sure the switch
position is the way you want it. Up is engine off and down is engine
on is the way i got mine. I think whats happen is you got the
throttle stick to cut the engine off also. I think the default setting
is 5 % of the throttle stick is were the engine will shutt off. Make
that 5% --------> 0%
Old 10-09-2003 | 11:13 AM
`3D
There have been times when (in a panic) that I wanted to cut the engine and it wouldn't because I was at mid stick...so I changed it to 50% so it will cut when I want it too.
Old 10-25-2003 | 11:22 PM
Mikes machines's Avatar
Even when I max out the travel on mine it doesnt seem to move far enough to shut the
engine all the way off. It could use just a little more travel. Any ideas?
Old 10-27-2003 | 07:11 AM
`3D
Increase throttle cut % and/or throttle atv on low side.
