What is the function of mufler ?
A lot of discussion in this forum talking about selection of mufler to improve the performace of an engine.
Honestly I got confused.
Because I though we need a mufler nothing more than to keep the noise down. But now I am sure that it does much more than that.
Please allow me to ask these questions :
1. How does mufler work to achieve top performance of an engine ?
2. What are the selection criteria to find a good mufler ?
Thanks a lot [8D]
Thanks a lot [8D]
WI
A muffler is not only necessary to keep noise down. A 2 stroke engine like we commonly use with our heli's won't run worth a damn without one. In a 2 stroke engine the fuel/air mix first goes into the crankcase, then up through transfer ports into the combustion chamber. Without a muffler a good portion of it would go right out the exhaust port. The back pressure from the muffler is what stops this from happening. A "tuned pipe" or "tuned muffler" is one that is optimized for a particular operating condition and gives a substantial increase over a standard muffler.
If you don't need the extra power, any good muffler designed for your heli will do. If you are looking for a little extra power, contact whoever you intend to buy from and tell what heli and engine you have and they can recommend one.
Hope this helps,
Mike
Hope this helps,
Mike
ChopperMike,
It was help me a lot, thanks.
What is "tuned pipe" or "tuned muffler" ? any abvious physical different we can see compare to the standard one ?
Again, Thanks in advance
One other point to that is, in my case anyway, was the heli was giving me quite a headache whilst learning to hover. I installed a Zimmerman which lelped enormously and wasn't so easily fatigued.
Freff
Freff
