SET UP
My Feedback: (14)
MD
HERE'S ANOTHER STUPID QUESTION. JUST GOT MY BIRD TOGETHER. NEED TO SET UP TX HAVE A HITEC ECLIPSE 7 QPCM . HAVE A HUMMING BIRD PRO WITH SEPERATES HITEC HS-55 SERVO'S 370 MAIN MOTOR PG-03 GYRO 8 CELL AAA BATT PACK 9.6 VOLT 720 MAH .NOW FOR THE QUESTION. WHILE READING OVER MANUAL ASK FOR THROTLE CURVES AND OTHER SETTINGS PAGE AFTER PAGE LEARNING THE TX IT SAYS IF YOU ARE A BEGINNER AT THIS ASK SOME ONE EXPRIENCED IN THE HOBBY FOR SETTINGS. SO I AM ASKING DOES ANY ONE KNOW WHAT THESE SETTING ARE OR SOMETHING CLOSE.TO GET STARTED . I CAN ADJUST FROM THEIR[sm=spinnyeyes.gif] THANKS FOR ANY HELP!!!!!!!!!!!!!!!! IN ADVANCED
{IF I COULD GET IT IN THE AIR - I AM SURE I CAN CRASH IT }
CA
If I'm not mistaken, a Hummingbird Pro is a fixed pitch machine. If this is so, then you do not need a lot of the heli capabilities of your radio. In fact, if your gyro is a Heading Hold (HH) gyro, then you could get away with programming your radio as an airplane. The elevator and aileron channels could connect to the cyclic servos, the rudder channel could connect to the tail rotor control, and the throttle could connect to the main rotor motor control. Here's why:
Pitch and throttle mixing and curves only apply if you have a collective.
Revolution mixing only applies if you do not have an HH gyro.
When and if you move up to a machine with a collective, then you can worry about those things, because you will have more experience.
My Feedback: (14)
MD
HEY WISDOM-SEEKER THANK YOU WAS GETTING CONFUSED DO HAVE A RAPTOR 30 THAT IM SETTING UP ON THIS RADIO TO WAS NOT SURE ON THE MICRO FP MAKE'S SENSE NOW THANKS ALOT GOING TO GIVE IT TRY.SEE WHAT HAPPENS NOW HOPEFULLY I 'LL BE HOVERING IN FEW. THANKS FOR YOUR HELP BUD!!!
{IF I GET TI IN THE AIR- I KNOW I CAN CRASH IT}
CA
You're welcome. But, remember that hovering is not an easy thing to do. By their nature, helicopters are unstable, and it requires constant control and concentration to get one to fly properly. If you haven't tried flying on a simulator, I would recommend trying to hover there first. Crashing a virtual heli costs nothing. Crashing the real thing is expensive.
My Feedback: (14)
MD
THANKS WISDOM SEEKER BENN ON GS SIM FOR ABOUT 2 MONTHS NOWNOSE IN ,OUT SIDE TO SIDE CAN ACTUALY CAN SPIN ALL THE WAY ARUOND A STAY STEADY FLY AROUND PRETTY GOOD BUT MAINLY FOCUS ON CONTROL. GOT PLENTY OF TIME FOR THE OTHER STUFF. G2 SAVED ME ALOT OF MONEY MY FIRST COUPLE OF DAYS GOT LUCKY I GUESS HEAR ALOT OF PEOPLE SAY 2MONTHS AND STILL CANT HOVER . KNOW THIS IS NOT REAL THING .BUT FEEL CONFIDENT TO GIVE IT A TRY WILL SEE STILL HAVE ALOT TO LEARN BUT PEOPLE LIKE YOU AND EVERY ONE AT R/C UNIVERSE WITH ALL YOUR HELP WITH NEWBE QUESTIONS THANKS BUD
JITTERSUP
JITTERSUP
