After flight
RI
After flight
OK it flys!!!! Now what should i do as an after flight procedure?????
I drained the fuel, cleaned the heli and checked all the bolts,what do i do for the motor?????
Thanks in advance.
David
Thanks in advance.
David
RE: After flight
Sounds like you have got a good idea already.
A clean heli is easier to see when something has gone wrong. Nuts and bolts vibrate loose. You have these two covered already.
How long are you going between flights? If you want the ideal solution for the engine, you are best stopping the fuel supply to stop the engine (put the throttle at idle and pinch the fuel line to the carb to stop the engine). If it's more than a few days before you fly again you could try putting a couple of drops of after run oil in the engine and turning it over a couple of times.
If you fly fairly regularly you probably will get away without doing either of these steps.
RE: After flight
Hello again, dlaque
That's off to a good start as far as regular flying. Just keeping it clean, so you can see everything, is the best habit to get into.
If the engine is not going to be run for an extended period of time (winter storage), you should pull it from the bird and store it with the crankshaft horizontal, or hang the bird from it's nose. With the engine on it's "back" inside the heli, there is no oil staying on the front bearings.
RE: After flight
Its a good idea to get a spray bottle with alcohol to wash off the fuel. If the fuel is allowed to stay on servo and antenna wires, the plastic insulation gets hard and cracks after a few months.
Banned
RE: After flight
I pull the fuel line from the engine, and from the muffler, and use a short tube to connect them to each other... seals the fuel tank so it can't accumulate moisture (and makes it much harder to dribble fuel all over the place)
