Xp 6102 or Rd 6 or 8000?
OH
I have to pick between these radios, what do you guys think? Also should I go with FM or PCM? I don't know the difference. Last question: Does the 6102 come in a heli version or is there just one version that is for planes and helis? I went to chiefaircraft.com and they list the Jr radios as either aiplane or heli, but the 6102 just says aircraft...Is this the correct radio?
RE: Xp 6102 or Rd 6 or 8000?
Pretty sure the 6102 has both airplane AND heli programming. The airplane version has a leaf spring that provides the ratcheting action for throttle. if you can't get the heli version, you might want to remove thte spring. (takes about 3 minutes). i use FM without problems, but the 20$ extra for the PCM is a good investment.
I just purchased a 6102 from heliproz, and yes they do come in 2 designations (heli/plane), the difference just being the no-throttle ratchet as mr. Spiff said and the switch designation and placement.
I went with the PCM.. whats 20 bucks?
